1994 Ford Thunderbird smells like coolant through vents
136,500 MILES • V8 • FWD • AUTOMATIC
GLIMLET
I just bought a 94 thunderbird which just had a new a/c systems in two months ago and then sat. When I turn it on it smells like radiator.......
any ideas?
May 20, 2008 at 6:15 AM
MASTERTECHTIM
  • 4,750 POSTS
if the heater core was not replaced then i think its leaking antifreeze into heater box. double check the rubber hoses going into heater core to make sure they are not lose
May 20, 2008 at 6:23 AM
GLIMLET
[quote:b5c3702214="mastertechtim"]if the heater core was not replaced then i think its leaking antifreeze into heater box. double check the rubber hoses going into heater core to make sure they are not lose[/quote:b5c3702214]
Thanks- and to get to the heater core I go through the inside dash??
May 20, 2008 at 6:34 AM
MASTERTECHTIM
  • 4,750 POSTS
yes. the dash needs to be removed to access the heater core.
May 20, 2008 at 7:34 AM
