1994 Ford Thunderbird shifter
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRIS BRADY
i need to remove the shifter on my car it wont go in to park i think i have a bent rod but it goes in to every other gear right below the shifter it makes a metal on metal grinding sound when i try to put it into park i would appreciate an answer so i can fix this problem thanks.
chris
Apr 2, 2010 at 7:16 AM
  • 110,248 POSTS
Are you able to replace the damaged linkage?
May 14, 2010 at 5:13 AM
