1994 Ford Thunderbird Odometer
235,000 MILES • 6 CYL • 2WD • AUTOMATIC
ATLANTABRVS
My odometer all of a sudden stopped working, the speedometer is working fine. Causes? Recommendations for repair?
Nov 10, 2008 at 10:19 AM
RYANBLIZZ
  • 35 POSTS
This is a very common problem with this instrument cluster. You can gamble from one on Ebay for about $60 and just replace the whole cluster - or there are a couple of sites I found that will repair it for around $200
I have even seen the gears sold separately if you would like to change them yourself... I have not done it yet, but will probably try eventually.
Supposedly this is caused when you reset your trip odometer while in motion. This causes the main odometer to bind and strip the gears. But I have seen them stop working for no apparent reason too. Good luck.
Ryan
Nov 11, 2008 at 1:29 PM
