1994 Ford Thunderbird odometer
PKBAYER
  • 1994 FORD THUNDERBIRD
  • V8
  • 70,000 MILES
How can I get odometer working?
Thursday, February 5th, 2009 AT 10:15 AM
NOSC
  • 11 POSTS
The problem you are having is a fairly common issue with the 90's Tbirds. The main problem is that Ford went as cheap as possible on some of the parts. The part in question is just a simple plastic cog /gear. The only way short of having someone do it for you is to pull the gauge cluster and replace it. There are 4 screws that hold this in there isnt a need to physically remove the entire dash. The top of the steering column however will need to be removed to make things go alot smoother.
Tuesday, February 24th, 2009 AT 10:48 PM
