1994 Ford Thunderbird Misfire 6
1994 FORD THUNDERBIRD
205,561 MILES • V8 • 2WD • AUTOMATIC
VAMPIREHAGER
My check engine light comes on and it starts to flash. I took my code reader and it sayed misfire of 6. Please can you help me. It eats up gas too. I dump $100 bucks a week alone in gas. I got white and some times blue smoke out of my tailpipes. When i drive it you can smell a strong gas smell. I have replace engine seals, sparkplugs and wires, new gaskets. Gas leaks from tailpipes. After i turn it off and come back to it you can smell gas really bad. Please Help Me. THANK YOU
Feb 24, 2010 at 4:31 AM
  • CERTIFIED EXPERT
Check the fuel pressure regulator and injectors if its leaking
Feb 24, 2010 at 7:20 AM
VAMPIREHAGER
Check all that is all good. I replace the computer and the check ing light went off for now. Its still misfiring thought.
Feb 26, 2010 at 8:03 PM
  • CERTIFIED EXPERT
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Feb 27, 2010 at 2:57 AM
