1994 Ford Thunderbird gas pouring out tailpipe
100,000 MILES • V8 • 2WD • AUTOMATIC
JASON MADSEN
  • 5 POSTS
I have a 94 thunderbird with a 4.6 v8.My problem is I have gas comming out of my tail pipe with white smoke.I mean alot of gas I ran threw 10 gallons just idiling while tring to figure out the problem over the last few days.Im getting good spark changed spark plugs,wires,new fuel pressure regulater and egr valve nothing has worked.I also have noticed my battery dies if I dont disconnect it.I dont know if it has anything to do with it but it all happend around the same time.
Apr 11, 2009 at 4:06 PM
JAMES W.
  • 2,394 POSTS
Is your fuel pump stuck on? Pull the vacuum line off your fuel pressure regulator and see if raw fuel comes out. If it does, your pressure regulator is shot.
Apr 11, 2009 at 4:26 PM
JASON MADSEN
  • 5 POSTS
vacuum line is dry.how do i check my fuel pump
Apr 11, 2009 at 4:40 PM
JAMES W.
  • 2,394 POSTS
You should be able to hear the pump run. If not, crack the fuel line at the pressure regulator.
Apr 11, 2009 at 4:55 PM
JASON MADSEN
  • 5 POSTS
I know my fuel pump is pumping gas its comming out my muffler not sure if stuck on
Apr 11, 2009 at 5:05 PM
JAMES W.
  • 2,394 POSTS
Are you sure it's raw fuel coming out the tail pipe? Does it burn? If you've got gas running out the tailpipe the engine oil has to full of gas also.
Apr 11, 2009 at 5:24 PM
JASON MADSEN
  • 5 POSTS
yes its gas i can watch my gas gage go down and the puddle under my muffler smells like pure gas
Apr 11, 2009 at 5:36 PM
JAMES W.
  • 2,394 POSTS
Well we're missing something here. If you had that much gas pouring into the engine, it wouldn't even fire.
Apr 11, 2009 at 5:56 PM
JASON MADSEN
  • 5 POSTS
trust me it runs but rough and smokes(white smoke) it gets about 5 miles a gallon or so only drive it to put more gas in it when working on it not sure whats wrong seems like my injectors are wide open.When its running gas comes out my tail pipes more than a drip a small stream if its on for a while.may be a short some where. my battery dies if it sits for a day or so.before this my car ran perfect it happend all the sudden
Apr 11, 2009 at 6:37 PM
JAMES W.
  • 2,394 POSTS
This will be one for the books when we figure it out. Try pulling an injector plug and checking the voltage at the connctor with "key off" and again with "key on". Let me know what you find.
Apr 12, 2009 at 5:18 AM
GALLETTA61
  • 10 POSTS
I had the same problem some years back, and it turned out to be a bad computer that was keeping one of my fuel injectors wide open. Not only did it stump 2 different mechanics, but when I finally towed it over to a Ford dealership, my engine was blown out from running it to long with this condition. Anyway even Ford couldn't figure out the problem. When the engine was finally replaced, and was started, the same problem was still there. Its only then that the mechanic realized that my computer was bad. replaced computer, problem solved, imagine that! Anyway, whether it be the computer or not, sounds like you have an injector stuck open.
Jun 14, 2009 at 5:48 PM
