1994 Ford Thunderbird engine wont accelerate
RALPH316
HI Everyone,
I have a 94 Tbird 4.6 V8 within the last few days i developed a cold start problem. When i would first start the car it would run rough and somethimes stall but after it ran for about 1 minute everything would be fine and you couldnt tell there was anything wrong.
Last night while driving home on the highway it i lost all power, the eninge was still running but if i would step on the gas it would bog down. could not get more than 700 RPM's. I am glad i was near home and was able to make it. SO if i put the car in drive i cant get above 5MPH. Made it home but dont want to try to start it in case it can cause more damage. Any thoughts?
May 30, 2010 at 3:47 AM
  • 75,988 POSTS
Clean out the idle air control valve and also the MAF sensor with an approved cleaner and test the throttle position sensor.
May 30, 2010 at 8:05 AM
