1994 Ford Thunderbird Engine stumbling on exceleration from
112,000 MILES • V8 • 2WD • AUTOMATIC
GALLETTA61
  • 10 POSTS
I have a1994 Thunderbird 4.6V8 with an intermitent problem that has every mechanic thats looked at the car stumped. This car can run fairly well for months at a time before all hell breaks loose. When it does, I get erratic idling, slugish exeleration, stumbling on moderate inclines, and last, but certainly not least; a steerability problem. The front end is all over the place, and it sounds as if im going to loose the front suspension. I changed the speed sensor since someone mentioned to me that when they fail, the power steering goes into default mode which is power assist for easy parking manuvers, and will stay this way at all speeds. Is this correct? Additionally, the car now consistantly stumbles and wants to stall from a dead stop, and only improves if I get on the pedal a little bit. I have had the front end problem problem over ten years now without a soulution. The stumbling from dead stops is something that started recently. Keep in mind this car was just taken out of storage less then a year ago after sitting garaged for five years without being started. The only thing I replaced was a faulty fuel pump when I put the car back on the road. Any Ideas or advice would be appreciated.
May 13, 2009 at 5:45 PM
  • 75,988 POSTS
Engine Hesitating or Stumbling:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
May 13, 2009 at 7:50 PM
