1994 Ford Thunderbird
PAPADROS
Electrical problem
1994 Ford Thunderbird V8 Two Wheel Drive Automatic
where is the fuel pump injector relay located on a 1994 thunderbird
Aug 28, 2010 at 1:02 AM
  • 75,988 POSTS
Are you referring to the fuel pump relay-if so,see below:
https://images.2carpros.com/forum/automotive_pictures/12900_fp_61.jpg
The Integrated Relay Control Module is located at the RH front of engine compartment, mounted to upper radiator support.
Aug 28, 2010 at 5:31 AM
