1994 ford thunderbird
ODIUM462
1994 Ford Thunderbird 140000 miles, automatic transmission 2 wheel drive, new trany. Ok, Got gas leaking through cylinder 6 running all the way out both tail pipes. Replaced plugs and wires. car runs really rough. got a cylinder 6 misfire code and a pre cat O2 senson code. Dont know what to do. mabey fuel injector, spark not letting of enough spark. fuel pressure regulator. Where should i start. I know since the gas poured in the exhaust the cat is now bad. right know im trying to get it to stop dumping so much fuel into 6. what do i do????? O it's a 4.6 8 cylnder engine.
Jun 7, 2007 at 2:28 PM
XTREMERCR
I had the exact same problem with my 94 T-Bird, except it was cylinder 8. After changing everything you mentioned "plus the fuel rail and injectors" I thought I would try one more thing..." THE COMPUTER". Believe it or not I replaced it and the problem was finally solved. The computer was going out, therefore causing the #8 injector to constantly pour fuel into the cylinder. Sparkplugs couldn't ingite all the fuel. The only other place the fuel could go was out the exhaust. Hopes this helps.
Dec 24, 2007 at 1:19 PM
