Engine Mechanical problem
1993 Ford Thunderbird 6 cyl Two Wheel Drive Automatic
174000
Aug 26, 2010 at 12:51 PM
✓Experienced Mechanic
Test the coolant temperature sensor if okay-Clean out the idle air control valve and also the MAF sensor with an electronic cleaner CRC and test the throttle position sensor.
