1993 Ford Thunderbird rough idle when cold
TOUGHER2
Engine Mechanical problem
1993 Ford Thunderbird 6 cyl Two Wheel Drive Automatic
174000
Aug 26, 2010 at 12:51 PM
  • 75,988 POSTS
Test the coolant temperature sensor if okay-Clean out the idle air control valve and also the MAF sensor with an electronic cleaner CRC and test the throttle position sensor.
Aug 26, 2010 at 7:37 PM
