I was driving my car when it started losing power, the check engine light came on at the same time. I pulled off of the road check all the fluids (they were fine) I then pulled off (no check engine light) got the car up to 70 mpg when the check engine light came back on and the car cut off. I had the car towed home. I started right up, but ran rough. It would not start back up after that. I changed the ignition module, but the car still will not start. I sprayed a little starting fluid in the throttle body, but that offered no new results.
Dec 21, 2007 at 6:36 AM
