1993 Ford Thunderbird no heat
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
TNJONE
I have purchase and install a heater core for a 93 tbird now that the headace is over from installing core and reconnecting hoses I still donot get any heat I have also replace temperature sender and sensor in that process lost the reading on the temp guage.
Feb 18, 2008 at 10:52 AM
BLACKOP555
  • 10,386 POSTS
AHhhhhh rest assure this is a simple thing to fix more then likely you have a air bubble lodged in the system. put the front end up on jack stands, remove radiator cap and idle the motor untill it warms up then keep adding coolant till it stops goign down and bubbling.
Feb 18, 2008 at 2:14 PM
