1993 Ford Thunderbird Ford Thunderbird Overheating
KRHILL93
  • 1993 FORD THUNDERBIRD
Engine Cooling problem
1993 Ford Thunderbird Automatic 180000 miles
I bought a 1993 Ford Thunderbird a couple of weeks ago. A few days ago, it died on me while accelerating. Since then, it has been rough to start it from a stop, but as long as I accelerate gently, it will start. However, after 10 minutes or so the engine overheats, and a white smoke flows out from under the hood. Also, there is a rattling sound that seems to come and go. I replaced the thermostat yesterday, and filled the antifreeze up. Nothing. Any ideas?
Sunday, October 3rd, 2010 AT 3:39 PM
  • 109,885 POSTS
If you see white smoke from the exhaust, you have a bad head gasket and that is causing the problem. When coolant gets into the combustion chamber, it burns white.
Check that and let me know what you find.
Monday, October 25th, 2010 AT 10:31 AM
