1993 Ford Thunderbird engine runs hot
89,655 MILES • 6 CYL • 2WD • AUTOMATIC
HARRY OOOO
Had the car worked on a fer months ago. Had new S belt, pluge, wires ignition set and a new thermostate installed. The guy insured it was a replacement type 180. Well, when I drive the car it rund normal, aout in the middle of the heat range but put on the air, pow, it runs up to about a 1/16 inch off the RED hot mark.
Coud it be a bad thermosstate or maybe a hose calasping?
Aug 5, 2008 at 4:55 PM
  • 75,988 POSTS
Could be the Stat again and flush the cooling system -won't hurt
Aug 5, 2008 at 5:08 PM
