1993 Ford Thunderbird blower stuck on high
1993 FORD THUNDERBIRD
STOOPID
Heater problem
1993 Ford Thunderbird 6 cyl Two Wheel Drive Automatic
all functions of heat/ac work correctly but blower stuck on high. Replaced ECC unit in dash, replaced blower relay mounted under blower, also pulled plug on blower to check for internal short, blower is working correctly. My wiring diagram only shows systems using the rotary blower speed switch, not the ECC setup my car has. Any ideas would be appreciated
Apr 6, 2008 at 4:17 PM
You forgot the AC/Heater blower motor resistor this one controls the speed of the blower motor by dropping resistances or increasing it test it out see below
https://images.2carpros.com/forum/automotive_pictures/12900_blower_resistor_6.jpg
Apr 7, 2008 at 3:42 AM
STOOPID
thanks for your reply, the blower relay that I replaced is also called the blower resistor. It has been replaced with a new one from Ford....
Apr 7, 2008 at 4:13 AM
I've verified it-its the same thing-Check the EATC Module. All the wires at the resistor other than the orange and red wire which is the power input to the motor and black wire to ground are coming from the EATC Module-
Apr 7, 2008 at 8:08 AM
