1993 Ford Thunderbird Blower, no air movement.
90,000 MILES • V8 • 2WD • AUTOMATIC
TDHWORTH77
93 Tbird, has automatic temp control. Blower will not come on. Repaced blower motor, but still no air movement. Power present at blower motor plug when tested with tester, on one of two wires.
Nov 10, 2008 at 2:31 AM
2CARPRO JACK
  • 11,533 POSTS
If it has power, and wont work, then ground might be missing. Use a meter to check continuity to ground off the other (non power) wire.Or make a jumper and give it ground to see if the motor will work
Nov 12, 2008 at 4:22 AM
