1992 Ford Thunderbird radio connection
170,000 MILES • V8 • FWD • AUTOMATIC
PETELERIKA
my radio works. but shuts off when i come to a stop, or reverse, or turn my lights on. i herd it might be the constant battery wire but im not sure please help me
Jul 27, 2010 at 12:24 PM
EDWARD.S
  • 166 POSTS
Hi, First Remove The Radio Check The Connections On the Back Of it.Make sure You Have Power And Ground.This Can Be Checked With A Test light.once the radio is out try to move the wring and see if the radio goes out then.
Hope This Helps You,
Good Luck
Edward S.
Jul 27, 2010 at 12:52 PM
