1992 Ford Thunderbird radiator
TRAVIS2693
Engine Cooling problem
1992 Ford Thunderbird V8 Two Wheel Drive Automatic
is it possible to use a higher cooling radiator in this car.. for example an f250 radiator or something bigger then the one that is in it??
Sep 1, 2010 at 8:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
no need to upgrade the radiator unless you have a lot of performance parts installed. if so than you would want to go with an upgrade radiator made specifically for your vehicle, trying to rig one up made for another vehicle will not be easy or worth the work/money/time.
Sep 1, 2010 at 3:03 PM
