1992 Ford Thunderbird how do remove timing chain cover
WICKEDWITCHAKAMOM
Engine Mechanical problem
1992 Ford Thunderbird 6 cyl Two Wheel Drive Automatic
we can not get the timeing chain cover off. we removed the bolts on the front of the cover are we missing something
Jun 8, 2008 at 7:34 AM
MASTERTECHTIM
  • 4,750 POSTS
did you get the bolts from the oil pan. if you did the aluminum housings are tough to get off the alignment studs and you need to do alot of prying and tapping
Jun 8, 2008 at 9:02 AM
