1992 Ford Thunderbird Alternator- not keeping car running
124,890 MILES • 6 CYL • 2WD • AUTOMATIC
SJBELL
The car cut off on in the middle of a major highway. I took the altenator to the shop and they put it on a meter and said it was charging just fine.
I put it back in the car and got jump start it started. It ran for 1 minute and then cut off.
I went and bought another altenator and the same thing happens. It runs for a minute and then shuts off. I'm clueless as what the problem is. Can you help?
Sep 6, 2009 at 1:22 PM
  • 75,988 POSTS
Could be fuel or spark problem-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sep 6, 2009 at 2:49 PM
