1991 Ford Thunderbird spark plugs
1991 FORD THUNDERBIRD
DONOVANMC
1991 Ford Thunderbird V8 Two Wheel Drive Automatic
How do i change the spark plugs on a 1991 Ford Thunderbird 5.0L V8 mainly on passenger side.
Jun 25, 2010 at 10:02 AM
RACEFAN966
  • 5,029 POSTS
Ok you will need a ratchet and plug socket 5/8 and swivel and extention. Now it is not easy so do it when it is cold. Move any hoses out of the way and remove spark plug wire from plug and remove plug, install new plug and plug wire and move to the next plug. I know it it tight but that is just how it is there is no quick trick. Before remove plug wire from plug turn back and forth before pulling and pull it off by the boot not the wire if it is hard to reach then buy a spark plug wire pliers. See Pic.
https://images.2carpros.com/forum/automotive_pictures/249564_images_6.jpg
Jun 26, 2010 at 2:09 AM
