1991 Ford Thunderbird Headlights
1991 FORD THUNDERBIRD
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
JJD241
My headlights go off by themselves. Turning them off and back on works but they will go off again sometimes. I think it is the switch (wiggling it a bit also turns them back on). How do I remove and replace the pull type switch. I hope it does not entail removing the dash!
Nov 9, 2008 at 3:33 AM
RYANBLIZZ
  • 35 POSTS
I had this same problem on a 1993 Cobra when I ran it with the high beams on. For me it was the actual switch overheating.
I am pretty sure you have to remove the dash to get the switch out. I have a 94 Thunderbird now and I know you have to on this one. It isn't too bad, two bolts on the bottom and something like 6 screws and it all pops off.
Have fun,
Ryan
Nov 11, 2008 at 10:05 PM
