1991 Ford Thunderbird brake problem
56,000 MILES • 6 CYL • 2WD • AUTOMATIC
SINKIDCITY
have no brake pedal .. new master cylinder ,caliper,lines,and booster is 2 months old ... caliper was frose up after changeing rotor and caliper would not bleed got new master cylinder and it bleeds but when start car there is no pedal but when bleeding there is a pedal .
Feb 1, 2010 at 2:10 AM
HMAC300
  • 48,601 POSTS
from your description you have air in the system and it needs to bled out again. But do the whole system and if you can rent a power bleeder use that.
Feb 13, 2010 at 10:54 AM
