1991 Ford Thunderbird battery
DOUGIE22
  • 1991 FORD THUNDERBIRD
  • 6 CYL
  • 164,000 MILES
I bought a new battery and put in the car for three days have not used the car except to open the trunck. This is the second battery something is killing the battery it want open the trunk or if turn the dome light on. Thanks if you can help. Doug
Monday, March 16th, 2009 AT 4:43 PM
BLACKOP555
  • 10,371 POSTS
Pull one fuse and check to see if battery stays up. Then pull the next fuse the next day
keep this up till drain is stopped
last fuse pulled is the one causing the battery to die.
Thursday, March 19th, 2009 AT 10:51 PM
