1991 Ford Thunderbird
1991 Ford Thunderbird Automatic 264000 miles
ford thunderbird 1991 turns over but does not start. checked fuel pump reset. has 1/4 tank gas oil and antifreeze levels good recently ran low low on fuel
Apr 16, 2008 at 1:54 PM
  • 75,988 POSTS
Try doing below
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Fuel pump and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Apr 17, 2008 at 11:57 AM
