1990 Ford Thunderbird starter
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
RSWOYER
will not start or turn over had start check was fine but in new battery and silenoid not sure where to go next
Feb 2, 2010 at 2:19 PM
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Feb 2, 2010 at 4:20 PM
