Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Thunderbird
Engine
Starter
1990 Ford Thunderbird starter
1990 FORD THUNDERBIRD
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
RSWOYER
MEMBER
1 POST
will not start or turn over had start check was fine but in new battery and silenoid not sure where to go next
Feb 2, 2010 at 2:19 PM
Experienced Mechanic
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Feb 2, 2010 at 4:20 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
