1990 Ford Thunderbird Hi
178,518 MILES • 6 CYL • 2WD • AUTOMATIC
BERNARD CAM
Hi my thunderbird wont start it`s got a new fuel pump an a new fuel filter an new spark plugs ,cap an rotor an wont start
Sep 1, 2010 at 9:49 AM
HMAC300
  • 48,601 POSTS
is there good spark? will the engine turn over? is there fuel pressure? If you have all of these then it's something internal like a timing chain, low compression etc. See if yo have spark and fuel a nd stick a finger in a spark plug hole with a rag and crank the car, see if you feel like'it's got good compression. if it dooes then go to the tune up site here and it will go through a step by step of how to check your ignition system.
Sep 3, 2010 at 11:29 AM
