is there good spark? will the engine turn over? is there fuel pressure? If you have all of these then it's something internal like a timing chain, low compression etc. See if yo have spark and fuel a nd stick a finger in a spark plug hole with a rag and crank the car, see if you feel like'it's got good compression. if it dooes then go to the tune up site here and it will go through a step by step of how to check your ignition system.
Sep 3, 2010 at 11:29 AM
