Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Thunderbird
Trouble Codes
P Codes (Powertrain)
1990 Ford Thunderbird block codes
1990 FORD THUNDERBIRD
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
M.LOMAN
MEMBER
1 POST
where are the engine ID, or casting codes located on the block of a ford 3.8 liter V6 ?
Apr 22, 2009 at 12:25 AM
MIKE H R
MEMBER
The quickest path to block
identification is the casting
number and date code found
above the starter on the
right-hand side of the block
Apr 22, 2009 at 1:47 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
