1990 Ford Thunderbird abs problem
1990 FORD THUNDERBIRD
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUANVILLALPANDO
hi my car has the teves 2 abs system and this is what happened my brakes were working properly but the pump was noisey due to a broken piece inside so i replaced the broken part and ever since then i get the anti-lock light and brake light i have the hard pedal also i mean this is what happened i used electric cleaner on the connections and now i don't know if that could've damaged the harness i mean the pump runs and because i can hear it (could it be weak?) if i put a pressure switch that doesn't work the pump doesn't run so i'm guessing the pressure switch is good altought i'm not sure the valve system is good also because it works good i bought an used accumulator which i'm pretty sure is good since it was guarantee not 100% sure though, the relays are new the fuses work my pressure hose is not clogged but no fluid seems to be sucked from the reservoir and when i turn the key the pump just runs and runs it doesn't do the test that it used to do when i could hear the abs control working what could it be?
Apr 3, 2008 at 6:21 AM
MERLIN2021
  • 17,250 POSTS
If the ABS light is on, go to a shop that can read brake codes, or "C" codes, this will tell you if the pump is no good, anything else is guessing!
Apr 3, 2008 at 6:25 AM
