1989 Ford Thunderbird Temp Gauge Indicates Overheating, but
189,000 MILES • 6 CYL • 2WD • AUTOMATIC
MVICKROY
The temp gauge in my T-bird indicates that it is overheating periodically. When this happens, I have noticed that if I simply stop and put the car in park, wait for a few seconds, and put it back in drive, then the issue is resolved for the rest of the trip. Occasionally, all I have to do is slow way down, and it corrects itself.
When this happens, I noticed that the air coming out of the vents is cool, even if it is set for hot. Once the indicator goes back to normal, then the hot air comes out. There are no smells of coolant, which I have noticed in every other car I have had that has overheated.
I have checked the coolant levels and ensured that there are no leaks. I have checked that the fan is running when this occurs.
What should be my next step in troubleshooting this? What does this issue indicate?
Thanks!
Oct 18, 2010 at 10:31 AM
  • 110,248 POSTS
If you loose heat, it sounds like there is an air pocket and the system needs bled. Have you checked that?
Oct 25, 2010 at 3:20 AM
MVICKROY
I can't find any valves that would allow me to bleed the air out of the system. I've looked in my Chilton manual for how to do this, but it doesn't offer any info. I've found some websites that discuss the process, but they all refer to these valves that I don't seem to have. Is there some other trick to bleeding the system? Should I try just draining all the coolant and replacing it? I don't know where an air pocket might be...
Oct 26, 2010 at 11:07 AM
  • 110,248 POSTS
Start the engine, turn the heater on, and loosten the return line from the heater core. If there is air in there, it should come out. You will, however, loose some coolant too.
Oct 26, 2010 at 1:34 PM
MVICKROY
Aha! Thank you sir!
Oct 29, 2010 at 6:25 PM
  • 110,248 POSTS
Let me know if it helps.
Nov 1, 2010 at 5:54 AM
MVICKROY
Yes, that must have been the problem. Thank you very much for your help!
Nov 3, 2010 at 2:51 PM
  • 110,248 POSTS
Glad to help. Let us know if you have questions in the future, and thanks for using 2carpros.com.
Nov 4, 2010 at 12:37 AM
