1989 Ford Thunderbird speedometer
86,000 MILES • 6 CYL • 2WD • AUTOMATIC
HANDYDANDY
speedo wavers 5-10 kph at highway speeds ,less erreatic at lower speeds . trans shifts normal
Jul 23, 2010 at 9:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
do you have the electronic instrument panel or the basic style? if basic then it should have a speedo cable which is probably getting kinked up. if it's electronic then the vehicle speed sensor (VSS) drive gear (where sensor connects to tranny) may have some damaged teeth .
Jul 23, 2010 at 11:56 AM
