1989 Ford Thunderbird does not start right awaywhen left af
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
FORDLUX
3.6 engine non turbo; initialy starts ok; if the day is hot when I stop (and I turn it off) and come back to use it just does not start (the starter does not engage at all). After maybe 15 minutes wait it starts ok. As far as I know the o2 sensors have never been replaced and the battery seems ok.
So I speculate that the starter is the culprit or the selenoid but I read somewhere that maybe the O2's could be the problem or something in the engine gets hot and the computer system shut down. Thanks a lot.
Nov 18, 2008 at 2:58 PM
  • 110,251 POSTS
Hi:
You will need to test if there is power to the starter when this happens. If there is power, replace the starter. No power, check the relay.
Nov 21, 2008 at 7:06 AM
