1988 Thunderbird Turbo Coupe
1988 FORD THUNDERBIRD
SNIPER2207
  • 8 POSTS
1988 tunderbird turbo coupe
170,000 miles, 2.3L Turbo, 5 speed
hey guys. i bought this turbo coupe from a guy saying it only needed a new battery. got it home, installed a NEW battery and still have the same problem. here are the symptoms, i hope someone can clue me in on a fix:
turn key over to start the car. engine barely turns over, most times not enough to start but sometimes i get lucky and it fires (acts like its not getting enough juice from the battery). tried hooking jumper cables up from a running truck but they didnt help the cranking speed. added an extra heavy duty ground from the battery to the frame and from the engine block to the frame, didnt help. replaced the solenoid with a new one, same problem. checked the wire from the solenoid to the starter and it looks fine and tight on both ends. both wires from the battery are in good shape as are terminals. the only thing i can guess is maybe the starter is on its way out. if anyone can give me any ideas you would be a hero! thanks alot! cory
Jun 20, 2007 at 10:24 PM
SNIPER2207
  • 8 POSTS
turns out the starter was the problem. i took it to autozone to have it tested and ended up getting a early 4th of july show with sparks and such flying out of their machine! ....needless to say it starts and runs like a champ now....
Jun 28, 2007 at 2:14 AM
