1988 Ford Thunderbird low turbo boost
ALLEN 1958
Engine Performance problem
1988 Ford Thunderbird 4 cyl Two Wheel Drive Manual
have a 1988 thunderbird turbo coupe, 2.3, I have an 18 lb trubo charger and i'm only about a 3 to 5 lb boost what could be causing such a low boost?replace turbo charger 10.000 miles ago. could it be the converter?
Aug 13, 2008 at 5:52 PM
1988FORDTURBO
  • 9 POSTS
I had the same problem with my sock turbo. All I did was replace the turbo tube and my problem was solved.
Oct 21, 2010 at 4:55 AM
