1988 Ford Thunderbird engine overheating
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
REDMACH-T
Hi, I own an 88 T bird turbo coupe that tends to overheat whenever I DO NOT run the air conditioner. Whenever I do run the a/c, the engine temp is normal. My cooling system is a dual fan setup. Could this be a fan motor or, fan relay, or fan control switch issue?
Jul 6, 2010 at 5:44 AM
MERLIN2021
  • 17,250 POSTS
Could be any of the above. check the fan motor first by running a fused jumper from the battery, if it runs, check the ect(engine coolant temp) sensor, and relay.
Jul 6, 2010 at 6:05 AM
