Hi, I own an 88 T bird turbo coupe that tends to overheat whenever I DO NOT run the air conditioner. Whenever I do run the a/c, the engine temp is normal. My cooling system is a dual fan setup. Could this be a fan motor or, fan relay, or fan control switch issue?
Jul 6, 2010 at 5:44 AM
