I have a gt40 upper and lowe intakes with the 98 explorer fuel injectoers I put the stock injectors back in after the 1s that were in there started flooding my engine so. After I replaced the injectors the power is gone and engine is stalling and running rough all ignition are fine fuel pump is fine filters are fine compression is fine plugs r fine the injecters r used did I mention that I didn't put them back n the same order they came. Out does tbhat matter should I get new injecters help please and thank you!!
Apr 28, 2010 at 1:35 PM
