1987 Ford Thunderbird fuel pump
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
BITESIZE69A
fuel pump isn't working, and i was wondering if their is a safety switch for if you are low on oil automatically shuts the fuel pump off, i already checked the switch in the trunk.
Dec 18, 2007 at 7:49 AM
MERLIN2021
  • 17,250 POSTS
If there is, it would be screwed to the side of the oil pan, What you should check, is to see if power is getting to the connector at the pump!
Dec 18, 2007 at 8:13 AM
