#1 set your parking break
#2 take the break lines off.
#3 you will see two bolts one on top the other on bottom take them out.
#4 it sould fall right out
#5 then reverse your moves putting the new ones back on.
#6 bleed your break lines to get the air out you will need two people to do that.one to pump the other to bleed.
Mar 24, 2006 at 11:06 PM
