1987 Ford Thunderbird
WEEZTWAYNE
  • 1987 FORD THUNDERBIRD
Electrical problem
1987 Ford Thunderbird 6 cyl Wheel Drive Type unknown Automatic 212456 miles
how to check ground wire cause battery wont charge
Sunday, December 23rd, 2007 AT 2:06 PM
POET042005
  • 134 POSTS
The ground wire is located on the block I believe on the left side of the motor next to the motor mount. Just need to make sure that its tight and not damaged.
In my opinion it sounds like you have an alternator problem or a bad bettery, possibly even a bad connection at the batter post. Hve the battery tested (do you own a multimeter) if the batter passes have the alternator removed and taken to a auto parts store to be tested.
Let me no Im here to help
Rich
Monday, December 31st, 2007 AT 5:44 PM
