Hey. I need to change the touchpad code, or keyless entry, whatever you call it. How do I go about doing it.
Thanks
Friday, July 27th, 2007 AT 11:40 PM
1988FORDTURBO
MEMBER
You first need to take the inside door panel off. Next you will remove the insulation. Then you will remove the pin that looks kinda like this ]. Finally you will follow the cord through the inside of the door unplug it and pull it off of the clamps that hold it to the door. Then you will be able to pull it out of the door. Or you could go get a Chilton manual from Auto Zone or Advanced Auto or some other auto parts store and it will have a diagram of how to do it.
