How do you replace the calipers on a 1987 ford thunderbird?
Mar 24, 2006 at 10:35 PM
Set the parking brake, disconnect the brake lines, and remove the upper and lower caliper bolts so the caliper comes off. Install the new caliper by reversing those steps, then bleed the brake lines with two people—one pumping the pedal and one bleeding—to remove air.
The owner asked how to replace the brake calipers on a 1987 Ford Thunderbird. The expert said to set the parking brake, disconnect the brake lines, remove the two mounting bolts, install the new caliper in reverse order, and bleed the lines with two people to get the air out.
