1985 Ford Thunderbird Speedometer and Odometer not working
1985 FORD THUNDERBIRD
DDS08D
Interior problem
1985 Ford Thunderbird V8 Two Wheel Drive Automatic
I have a 85 Ford T-Bird with digital dash. The speedometer stopped working first and then the odometer stopped working afterwards. I just replaced the speed sensor; but the speedometer/odometer still does not work. All the other indicators still work though. Before the malfunctions, I did do some work behind the instrument cluster to get the gear adjuster-Park, Neutral, Drive, etc. to line up correctly. Do you have any idea what is wrong?
Jan 29, 2009 at 12:53 AM
BILLYMAC
  • 2,204 POSTS
hi first you need to check plugs in back of the cluster.check all grounds.if these are ok you will need another cluster. thanks billymac
Feb 1, 2009 at 11:06 PM
