1984 Ford Thunderbird staring
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADAM01
when you roll the startier just clicks whats the peolben
Sep 17, 2008 at 10:51 AM
BLACKOP555
  • 10,386 POSTS
check to make sure the battery cables are clean and free of corrosion, and also TIGHT.
next step would be to try and manually crank the starter by putting 12v on it if it just clicks chances are the starter is bad, if not and the starter cranks, then i would suspect a bad relay.
Sep 17, 2008 at 12:50 PM
