1972 Ford Thunderbird Engine back fireing & stalling
1972 FORD THUNDERBIRD
78,000 MILES • V8 • 2WD • AUTOMATIC
MARVIN WELSHER
My car has a 460 engine and everytime I put the vacuum advance hose on it backfires and stalls out. I have put new timing chain and new distributor, new coil and msd, plugs and wires. I have never had this happen. When you leve the vacuum hose off , the car will run but sounds like it is missing.
Jun 17, 2009 at 8:36 AM
  • 110,244 POSTS
Is it backfiring through the intake or exhaust? Also, when you set the timing, did you have the vacuum advanced disconnected and plugged? Have you checked for other vacuum leaks? Finally, (no knowing the vehicle) have you checked compression?
Jun 26, 2009 at 3:03 PM
