When I put the car in reverse and start backing up the shifter falls into neutral.also it will come out of park into reverse by it self.Help
Jan 19, 2010 at 9:50 AM
HMAC300
✓Experienced Mechanic
try adjusting the shifter rod to cure the park reverse problem. It should be adjusted to go into park more. If tis has a fordomatic trans there is a possibility that he centr case support cracked as this was a common prpoblem with them. If it is it can be fixed while in your car......
